Is the first layer gap is different for each layer height option?
When I try to print other layer heigh than 0.19mm , for example 0.09, then the print doesn’t stick on the raft…
What s mean the value of 0.26 layer gap? Don’t tell me the gap between the raft and print because with a layer of 0.09 it is just impossible to have 0.26 under the raft otherwise you print in the air.
Thanks for explanantion if this forum si still alive…
Yes, the first layer gap is different for each material and layer height.
Below you can see the differences first one was 0.27 and second one was 1.17.
