Hi Guys this is the first model I printed with the Zortrax. Was printed with supports (bad idea) at 50% scale.
LOL… It really packed it with support did it? Looks pretty good though!!
Support is always good idea and never try to print without support, just for such of tiny model because it have micro machine size use 10degrees of support.
[quote name=Kyle]LOL… It really packed it with support did it? Looks pretty good though!!
[/quote]
Yes It’s awesome!!!, It looks like the ones printed at 100% in thingiverse
[quote name=Martin Olchanowski]Support is always good idea and never try to print without support, just for such of tiny model because it have micro machine size use 10degrees of support.
[/quote]
Martin, actually the program placed supports in the inner cavities of the block, those were are pain in the ass to remove, I had to use a drill to do it :[
Does the Zsuite have an option like in the UP software that you can stipulate a minimum hole area to use support ? That way you can still have normal support but have it left out of areas that are difficult to remove it from.
