Finally i got my own Zortrax and it works perfectly!
First thing i printed come out just perfect. I wanted to test the precision and the mechanical properies of the filament and the printer. Everything is just perfect, just the calibration has to be improved. When the 5 point calibration is implemented everything would be great!
The model is made on Pro/Engineer, print time 3h, support 80°, fillament ca. 20 gram, fill method middle.
Btw big thanks to the Zortrax Team for the great work. It’s a long time ago i saw a such simple to use and high quality product.
No I made that by my own. Could be that things like that are on Thingiverse but i wanted to learn something about clips and printing. Thats the reason i draw it by my own.
I can give you the stl file so you can print it too. But its not perfect right now because i forgot the offset of the surfaces touching each other. So because of the tolerances it works but not perfect.
