Dalimali:
Dalimali:
I do both thanks .
well from the pic it clearly looks like your bed need to be properly leveled up,even at the naked eye there is quite a significant inclination...how do expect the printer to work?!
The picture shows the nose embedded in the platform ......
Is your hot end getting hot? If there is solid un-melted plastic at the tip of the nozzle it can prevent the nozzle from making electrical contact with the PCB, in which case the printer doesn't know that the nozzle has touched the bed and so it keeps raising the Z axis waiting for contact. The basic height-finding feedback loop is very simple: it raises the bed until it senses electrical contact between the nozzle and the PCB. There are a number of things in this circuit: the nozzle itself (make sure it's clean), the PCB, the connector from the PCB to the motherboard (the small one) the wire from the hot end to the head PCB terminal block, and the big ribbon cable from the head PCB to the motherboard. If any one of these is open, the circuit will not close and the printer cannot detect the nozzle kiss.
Since your printer has been working and suddenly stopped, I would take a very close look at the small connector on the bed PCB, both male (PCB) and female (cable) sides, and especially the connections of the male header to the PCB. I damaged mine once accidentally while scraping parts off the bed.
julia
yes which is a consequence of how badly leveled your printing bed is
Looks to me like your adjusting screws may need to be tightened 3 to 5 revolutions until the socket head cap screw heads (SHCS) stick up a little more from the bed. I had some problems leveling my bed when the top of the SHCS were almost flush with the bed because the holes in the bed were catching on the SHCS heads and preventing continuous height adjustment of the bed. I'd adjust the screw several times with no change in bed level and then suddenly the bed would pop up a few tenths of a mm as one of the holes slipped off the screw head.
Mike
julia
FORGET, you do not understand what happened. :wacko:
Mike
The picture was taken after stopping the printer before major damage.
No. His bed is off-level in the photo because the printer failed to detect nozzle contact during auto-calibration, so the bed continued to rise beyond the point where it should have stopped automatically, pushing one corner of the bed down on its spring suspension.
