Hi Support Team,
the first lower wall lines do not correspond with the upper one, see pictures.
Is it possible to adjust this to create multiple wall lines at the beginning?
Stefan
Hi Support Team,
Stefan
Hello Stefan,
could you share the files (.stl, .zcodex) with us?
Best regards
Hi Karolina,
this phenomenon is independent of the object to print.
Attached is an example file.
Best regards
Stefan
Zortrax Support.zprojx (369.5 KB)
Hi Stefan,
thank you for the model. Now I can see your point - however, there is no parameter you could adjust in order to create multiple wall lines.
Best regards
