Get closed
Can someone tell me, can I get close this on the picture, I tried to set some parameters but with no results
I printed solid, this is the side with the support
Also you can see the gap on the picture right
Thank you
Are you talking about what seems to be a warped surface on the bottom of the part?  What filament?  Are you using an enclosure?  What are the approximate part dimensions?
