The reason that it is sometimes difficult to remove the base mat from the heated platform is because all of
those holes in the platform are cylindrical, and the plastic sticks in the holes, too well sometimes.If the holes were slightly tapered by 1 or 2 degrees, wider at the top, then the base mat would lift off mucheasier.
I thought that filament sticking to the holes was a benefit since it helped to anchor the raft on the next print.
I am a mechanical designer, making real-world engineering parts, gears, bearing housings for pre-production
checks, some models have to be printed in two or more parts to fit onto the table.Not the occasional jewelry, ear-rings and key ring fobs
We're all very impressed, I'm sure.
The block needs to be made of stainless steel, not Aluminium
Aluminum is used for the heater block because its primary function is to conduct heat from the heater to the nozzle and to add some thermal mass for stability. Stainless is poor heat conductor compared with Al, and so would probably not work as well in this application I think. A bit more power in the heater might be nice if the PSU, cables, connectors, PCB traces, MOSFETs etc. could supply it and the PID loop control it.
The reason that it is sometimes difficult to remove the base mat from the heated platform is because all ofthose holes in the platform are cylindrical, and the plastic sticks in the holes, too well sometimes.If the holes were slightly tapered by 1 or 2 degrees, wider at the top, then the base mat would lift off mucheasier.
Ignoring the fact that perfboard with conical holes is not commonly available and would be a real b*itch to manufacture, the whole point of the perfboard is to promote adhesion of the raft to the platform - many users have trouble with insufficient adhesion. Get yourself a good scraper, it's really not that hard to separate the raft from the perfboard. Better too much adhesion than too little.
...it would be a good idea to have a print abort button on the front panel.Where the printer stops all printing and heating and then goes back to the origins and shuts off.
This feature exists. Press and hold the encoder button - the print will pause and a menu will appear with options, among which is "stop the print process".
The extruder block and the heated platform currently heat up separately, why can they not heat up together.
One of the Great Mysteries of the age...
As a mines and oil rigs field service fitter of 25 years I would like to repeat my continued assertion that the day they put a daily bag limit of 10 on mechanical engineers (especially self proclaimed) I will buy myself a shiny new rifle.
Easy now, no need to be hostile. Not ALL of us think we know everything (though a few such as myself really do know everything). :lol:
An oil field service fitter is not an engineer, usually just another ignorant grease monkey grunt working out in all weathers,
It is us real engineers sitting in cosy warm offices in the city centre who tell the grunts what to do.
