I made the base design in solidworks, exported as STL. Imported the STL in MeshLab to create the voronoi pattern.
Printed on my M200 using these settings:
Material: Z-ABS, black
Layer height: 0,29 mm
Support: 10 degrees (20 degrees would probably have given a cleaner print, but that would have been a real pain to remove). I used support lite.
Total print time: a bit under 20 hours
The height of the stand is about 20 cm and it is about 11 cm deep so the ear pads of my headphone fit.
Tutorial for the voronoi pattern:
