Previously was facing Perforated Plate Contacts Issue (Error #033) and platform was hitting the nozzle. Soon I found the cable on the platform was damaged and replaced with new heatbed cable and clean the blocked nozzle with acetone. After that I conduct auto-calibration and it started to load material but it does not stick to the platform.
I then suspect is the platform given there it has damaged by the nozzle and then I replaced it with a new platform.
But the problem still persist and I have checked the following :
- The temperature on heating block is around 200 degree
- The temperature of the platform is around 53 degree
- Resistance of the heating rod is 13.9 Ohm.
I tried to use another nozzle, auto calibrate it 3 times and apply small amount of glue and still no luck.
Please help ![]()
