Nice design - however it looks that your printer needs some maintenance, please check this manual: http://support.zortrax.com/hc/en-us/articles/201002262-XYZ-Axis-Maintenance.
wow ! I thank you so much !!! I had not seen these tutorials and are very interesting, I have already had to disassemble the extruder to free it from a piece of wire stuck
why do you think he maintenance problems to the axes? I greased repeatedly guides and regularly check the tension of cinghi and the proper tightening of mechanics.
the only problem at the moment is the fan that is becoming increasingly noisy, I would start to change with a better product
You have a lot of horizontal lines…normally the Zortrax makes almost perfectly flat walls. That’s why Filip recommends the maintenance.
he horizontal lines are formed due to the smaller detachment from the base.
from good modeller prefer to do a bit of finishing and use the piece
