I want to print a draft model using mesh/shell.
It should be a closed shell,
but the result is really bad.
I use shell and wall thickness is set to 4 pcs.
Maybe this is because the whole top is not flat and Z-SUITE identifies them as different layers and gives each layer only walls. This is where the gap comes from.
Can I get the closed top without much model reshape? Here is the Zcode printing project.
rock.zprojx (4.5 MB)
Any suggestion would be great! Thanks.
