Hello!
Im thinking about buying an M200, so Im testing the slicer to see if it seems good.
I cant find where to change the wall thickness, its only 2 layers wide by default and that wont work for end use models. Can anyone tell me where to change it?
Hi, @fieldmouse.
Wall thickness parameter can be modified only when printing with Shell mode.
Could you show your model or send me the .stl file?
Hello @Marta,
I am having the same issue. I don’t want to print in shell mode, I need some infill.
I need to be able to adjust the thickness of the walls without changing part dimensions.
Thanks in advance.
This is a feature I’m still waiting…number of perimetral walls, number of walls around a hole
Hello. May I ask when do you plan to add this main and most basic function? Thank you. Lukas
