I have a model like circle.This circle has a small thickness 0,5 mm.When I tried to printed this model.Z-suite filled in the gap.I tried other slicer everything was normal.Any ideas for this issue guys ?
Could you provide an .stl file? Unfortunately, I am afraid the wall is too thin, it should have at least 0.8 mm. You can also verify this thanks to the wall thickness analysis tool:
