I need to know the electrical schematic of the perforated platform
Hello I have a Zortrax M200. I need to know the electrical schematic of the perforated platform, to know the use of each wire of the connector (Black, Red and White)
Not going to happen, ever.
You don't really need a schematic for that, and the info you want is already on the forum.
http://forum.zortrax.com/index.php?/topic/2489-small-connector-broken-completely-off/?p=27710
Thanks Printz,
My connector is broken and the only solution that seems to give Marcin is that I continue to spend my money needlessly...
Thanks Printz,
You may try soldering on your own what is not recommended at all
Thanks Printz,
No problem, in Zortrax's defence most companies wont tell you how to fix the electronics of the devices they sell but it's often easy enough to find the info from other users.
When my connector broke off I just shorted the left two wires (these check if the bed is plugged in) and reattached the right wire as the existing contacts had broken off making soldering all 3 wires very difficult.
We are not trying to hide anything, more like trying to prevent self-repaired aka 'soldered' plates coming to our service as "JUST BROKE DOWN, LIKE THAT, I DINDU NUFFIN"
