we mill 4 axis small metal objects in our factory but we sometimes find ourselves in need of more complex shapes that would require a 5 axis machine.
since we do not get these jobs too often, and since we only make samples, i cant justify the huge cost of a 5 axis milling machine addition.
to solve this problem im looking at trying a lost wax casting approach to this.
the type of work we do is mainly fashion hardware and embellishments so the objects are jewelry like is size so i was looking to perhaps use our zortrax to print the objects and then either use a direct lost abs method or maybe use the printer to make a negative mold that i will cast wax into and then use the cast wax to do a real lost wax casting.
anyway, back to my question…its my understanding that while lost abs works to some extent, it doesnt burn out clean so the surface finish is not as good as lost wax, since the objects i will be casting are quite complex, and like jewlery they will require a nice finish, i dont think this method will work.
what i am thinking, is i will try this…i will print my object in abs , include the spout and air escape channels in my print…i will then tumble this object for several hours to achieve a nice finish ,and further refine the surface with a polishing tool on a rotary device…i will then place the object in plaster, cure it and rather than try to burn out the abs, i will place the finished piece in pure acetone to dissolve out the abs instead…my logic is that this may allow for a much cleaner removal of the abs , thus leaving me with a nice cavity to then cast my metal into(zinc in this case).
anyway, i will be documenting my experiment and if successful i will post the results with pictures but i was looking for advice and suggestions and basically what you guys thought of this approach.
as far as the casting process, im fine with that, i cast zinc in my factory all the time and im fine with that aspect… my concern is more about the properties of the abs and if it will fully dissolve in acetone and if so, what is the time frame im looking at?
im also wondering about perhaps a saturation point of the acetone, like after a certain point it will cease to dissolve the acetone and i will have to change out the solution…again, im not talking about a large object but rather something no more than 1"x1" piece of abs, maybe a little more for spout and air channels…
if this method works i will then look to refine to process, perhaps with another 3d printer more suited to small detail like form 1 but im not sure that resin will be effected by acetone.
ideally a direct wax 3d printing machine is what i need but the cost for one of those is huge.
form one has a fire cast resin but the results i have seen are poor, i dont believe it burns out as clean as wax and while a solvent to remove the material may be slower, if it works i believe the results should be as good as wax .
please let me know what you thoughts are on this method,…my main concern is the abs dissolving…would heating the acetone help?
