Bonjour,
Lorsqu’on met en pause une impression en cours depuis l’onglet “Mes appareils”, il n’est pas possible de reprendre l’impression depuis Z-Suite, il faut se rendre physiquement sur l’imprimante.
Cdlt
Daniel
Hi Daniel,
Which Z-SUITE version are you using and what firmware is installed on the printer?
Hi Karolina,
Z-Suite : 2.17.0.0
M200 Plus : 2.4.4
Hi Daniel,
Yes, it is impossible to resume the print from Z-SUITE as this requires the user’s action (you need to remove the material residue coming from the nozzle before resuming a print). However, you can do so via inCloud as you get a notification reminding you to undertake the action.
