Infill in %
Can someone tell me what the % infill settings the full, solid, medium, & light setting are please? An estimate would be great.
I've started offering my printer via 3D Hub and they state a 20% infill as standard.
Cheers
Cheers
I don't know what they are, but it'd be pretty easy to find out: print a cubed cm at each infill, then compare it to the reported density for the solid plastic.
See here for details of all the Z-Suite settings: http://support.zortrax.com/hc/en-us/articles/201809922-Z-Suite-Manual##poptions
Thanks LabRat, I would also have to calculate the mass of the wall sections though so I don't think it's as easy as all that. I suppose I could use the shell feature for one though. I may give it a go and see what it comes up with.
Thanks The6uest, unfortunately that doesn't answer the question though.
http://forum.zortrax.com/index.php?/topic/1453-infill-to/?hl=infill
Is this what you were looking for?  :)
I would say Medium infill is closest to 20% then.
thank-you YosemiteSam, exactly what I was after!
