Another newbie question: infill. Since there is no representation or explanation of what it looks like, one must reverse engineer it I guess. "Solid" actually seems to print a honeycomb with about 1mm cells? When you go to "medium" less material is forecast to be used, so I assume it is just larger cells? "Full" uses more, I will try that next, is it really solid (does not appear to be a small parts)? The honeycomb is oriented at 45 deg to the platform, is that invariant? So if one wanted the cells arranged 0-90 rather than 45-45 one would turn the model on the platform? Or does that just turn the cells as well?
I could run a bunch of test prints and discover the answers over time, but this must be common knowledge amongst the brain trust here!
