According to your release notes, the new firmware supports PrusaSlicer. I have updated my Inkspire yesterday to this new firmware, but I haven’t had any luck with printing files sliced in PrusaSlicer. I followed the setup instructions outlined in your support manual to setup the profile in PrusaSlicer. After slicing, the printer recognizes the file and tries to start printing. It lowers the platform into the resin, but then it stays there. The time is counting down, but after a couple of minutes jumps back up, starting to tick down again. Do you have any idea what might be causing that? I am using the original USB flash drive that shipped with the printer.
On a similar note, do you have any information as to the resin settings, so that i may configure my Zortrax resins in PrusaSlicer?
Could you send me the file that causes the problem? We will check it.
As for Zortrax Resins settings, all parameters are available in Z-SUITE (advanced options) when you choose particular type of resin and layer thickness.
Thanks for the reply! I am unable to attach a file here (presumably because I am too new to the forum). Is there any other way I could send you the file? I am new to this kind of forums, so please excuse me I am missing some obvious way.
Thanks for the information regarding the resins! I should have figured that one out on my own…
