Inkspire resin mix
Could you please add an option in the tools menu to bring the build plate down to the home location and slowly move it up and down to mix the resin in the reservoir? This would serve two purposes: stir the resin after it has been dispensed into the vat and mix the resin after a successful print so another print may be started.
Hi, @jbenyeda.
I will pass this suggestion to our specialists. However, remember that you should make sure that there aren’t any cured resin residues in the tank before launching another print, as they may damage the FEP film and LCD screen. In the meantime, you can move platform up and down from printer’s Menu>Tools>Platform.
