hi
yet again had a print that ‘ran dry’ (tank ran out of resin) overnight that is a pain
z suite told me 205 ml resin required i filled the tank right up at least 75 to 100ml of extra resin capacity there in the tank
had this a couple of times before … don’t understand… the z suite material estimation is object AND supports ? correct?? so how can it run out ?
Inkspire runs out of resin!
Does the issue occur with all models? What firmware and Z-SUITE version are you using?
