I have 2x Inkspire-v1 printers and am trying to find alternatives resins - as Zortrax own brand resins seem to have now been discontinued. I use Z-suite version 2.32.0.0 which has a couple of 3rd party resin options in the material pull-down menus. One of these options is Siraya Tech Blu Clear v2 which looked good, so I bought some to try. However, when I went to print the file, I found that this material was not available as a option in the printer (both printers have latest firmware v2.5.9). I was hoping not to have to go through the process of setting it up as an external material. Any suggestions?
Inkspire generally handles external resins well. As for me, I have been using resins from other manufacturers for a long time, such as eSun, Anycubic, and Phrozen. When it comes to profiles, I usually calibrate the exposure time and choose the appropriate exposure duration based on that. Regarding profiles, I modify the default Zortrax profiles by adjusting the exposure times accordingly. For example, if I’m using eSun Tough Resin, I select the Zortrax Tough profile but adjust the exposure times to match the resin’s specifications.
