I bought a new CAP Sensor for the printer, but I cannot find a Manual how to install it, because it is a separate part. Can you tell me how it has to be done?
For safety, turn off and disconnect printer from electricity.
Unscrew 2 cap sensor holding screws, remove the old cap sensor from the fan shroud, disconnect the signal cable. Be careful not to tear the connector from the cable.
Install new sensor in reverse order. Do not tighten screws too hard to not break the thread as you are screwing them into 3d printed part.
That should be it. Run platform calibration to check if it works properly.
