How did you fix them to the bed ? Is cork so heat resistent ?
Thank you for the information
I just replaced the screws holding the heated bed with longer ones and used those to hold the cork bed in place. Ideally I want to get either some aluminium or FR4 cut to sandwich the cork and push it hard up against the bed. Even still, it makes a significant difference now and hangs a little.
interesting result but after an initial "enthusiasm" of that being a ~12% shorter time, if you take into consideration that an average print is 4-5hrs long and many of them can be 10-30 hours long, then a 50-60sec in time saved is really very small and negligible.
BUT the insulation has another role too, so another thing that would be very useful if you were able to measure is to find one of these cheap watt meters and print twice the same let's say 5hr print, and measure what difference the insulation will cause in power consumption due to the lesser heat loss
I do not think that bottom insulation is useful because heat moves up and not down.
If you save some time heating up, you have to wait some more time to cool down the plate and remove the item.
An improvement for the heat plate would be to have a more even temperature also in the perimeter , the corners have a lower temperature that affects printing of large items.
If you don't think heat radiates from below the plate try putting your hand on it.
I have not said that heat do not radiates , I just said that it is not very useful .
Your reply is not funny , it is unusefull as isolating the plate bottom.
Take a look at the image of my avatar, I'm shure that seeing in colors you'll understand the concept.
I wasn't trying to be funny!
Have you actually tried insulating the underside of your hot bed ?
I have machines with insulation and without. The one with insulation heats up quicker, period. And stays warmer longer, reducing reheating times in between prints.
As you obviously have access to FLIR equipment, perhaps you could show a picture of the top of the bed and bottom for comparison ?
I'm no physicist, but I think radiation is quite different to convection, which is what your avatar appears to be showing btw.
