I would really like it if settings in the print settings window did not affect other settings - this has caused me trouble and lost time on many occasions. For example, I just changed the layer height from 290 to 190µ, and at the same time, the support angle and number of layers changed without me touching them. If you don't manually double-check every single parameter to make sure it hasn't changed, you can end up with settings you didn't intend.
Dear Julia,
Here is a link where you can report such issues: http://forum.zortrax.com/index.php?/tracker/
Chris
Zortrax Team
