Interior fill for 3D prints
I've made a print that is an 9" tall figure that I've done as a comission and is supposed to be Oscar like.  I'm about to fasten the print parts together but am considering filling the interior of this hollowed print with Titebond and fine sand to give it weight before I finish painting and sealing etc.
I’m curious what others have used and what they have found works well to fill interior figures with.  I’m wanting it to feel solid and obviously if you were to move it around, I wouldn’t want there to be any movement from the sand and also as some parts are fairly delicate, no expansion can come from the glue setting up etc.  Anyone use any liquid type filler or sand they would recommend?
Thanks,
Jason
Wood's metal?
https://en.wikipedia.org/wiki/Wood%27s_metal
Cerrobend is one brand and they sell  various alloys with different melting point ranges:
http://www.csalloys.com/products-cerrobend-alloy.html
Expansion could be an issue, even if the melting temperature isn't.
I'm going to experiment but bought some Smooth-on Polyurethane 380 (1hr pot), and going to mix with bb's of various gauge.  Think it should do the trick though.
I was going to say 385 but 380 doesn't shrink much and the cps is less than half of the 385. You should be ok.. If nothing else.. Fill it with Mercury.. :lol: :P
Looking forward to hearing about your results.
Only place I could find steel BB's on short notice was Wal Mart...:(  However they are going to work great and the larger bottle is pretty heavy and the bb's there are all one size of 4.5mm dia.  If anyone's curious.  Think they will work great.  Don't have any other prints right now similar to the one I need to do this, so I'm going to risk it and put the bb's in before hand, then chase with Polyurethane and take a big swig :)
..Fill it with Mercury.. :lol: :P
My grandfather was a geologist and always kept brown UV or chem resistant jars of this and that.  He used to always pour little balls of mercury into our hands when we would show up for holidays.  Explains a lot about our last families generation as a whole..
My dad was a chemical engineer and the little erlenmeyer flask of quicksilver in the basement was always a huge attraction.
But your dad didn't let you hold it and bounce it on the floor probably.  This is why your smrtr
