Hi ,
I have an inventure and it is a great printer .
but when I print with nylon the bed melts/gets grooves in the surface with renders it useless .
if I set the distance in the slicer to far away it doesn’t stick to the bed, and if I set it closer it melts the bed(it digs into the platform even with standard settings)
things I tried:
-using build surface plus
-new nozzle
-new hottend assembly
-software update
all advice will help .
kind regards
Louis Drappier
Hello Louis,
Could you show me photos of the filament and prints?
Please note that Z-NYLON is demanding filament and needs to be stored in proper conditions or it will gather humidity.
Below you can find useful tips for this material.
Hi pawel
I don’t have access to the printer now, but the filament is stored in a drybox and the prints are very good and the raft is the same thickness as my z-ultrat and PLA,.
I will reply the photos over the weekend.
Kind regards
Louis Drappier
