Is a temparature tower on the m200plus possible
I was wondering if it is possible to let the Zortrax m200 plus print a temperature tower in order to determine the best temperature to print without much stringing ?
It looks like the zsuite software only allows the setting of one temperature per print.
Kind regards,
Rob
watches tumble weed blow by
Hi!
I printed a temperature tower today on my Zortrax M200. You need to use another slicer - I used prusaslicer and add a command before layer change in the gcode. Then you do the script for the temp tower. After that you can use the .gcode to .zcode converter from Zortrax find in the download section. Hope this helps you.
Hi henke_83, great stuff, thanks for the info !
