Is it a minor bug?
Hi all,probably it's a minor bug(or i'm wrong), but i noticed that preliminary calculated "estimated print time" and "filament usage" are different when i"m rotating the model by 90 degrees (0 degrees -0h 40m ,1.63m (4g) ;90 degrees-0h 42m 1.63m (4g);180 degrees-0h 42m 1.64m (4g);270 degrees - 0h 41m 1.63m (4g)   ).I'm using 1.8.2.Setting are z-abs,layer-0.14,quality -high, infill maximum.Sorry if it's reported already.
No it is not a bug. It is most likely caused by different path of the print head and especially different orientation of infill geometry. Also support structures depend on the rotation of the model if there are some supports (i have not seen your model)
Exactly that
0 angle
4179
90 angle
4180
135 angle
4181
180 angle
4182
270 angle
4183
Hi ,thanks for replies.Everything's clear.
