Is it possible to stop/remove nozzle touchdown to centre of build plate
I’ve installed a non-perforated build plate and a z-axis stop switch so I no longer need the nozzle to touch down in the middle of the plate. In fact it has become very annoying as it leaves a blob of material right in the middle of the plate which needs to be picked off before the main print happens.
Is there any way to take this step out of the z-code?
Hi @VirtualBrown,
I can see your point. However, it is impossible to omit this step.
Best regards
Hello, I want to use a PEI springsteel build plate. How did you install the z-axis stop?
Can you help me here or send me instructions on how to do this?
Thanks in advance!
@VirtualBrown
Can you help me with the z-axis stop?
Hi, I bought a switch that sits on the shelf behind the build plate. It’s from a company called Z-Temp. I actually don’t need my one anymore, which country do you live in?
