Hi Michael,
My Zortrax M200 has printed about 1100 h now and I had my first shifting last week, using 1.6.1.
Did the axis maintenance, but got shifting again at the same height, and again 2 mm displacement.
Turned my part 90 degrees on the bed and got a good print.
The last week I have printed 24 parts, 74 h all together, but had shifting issue with only one of the parts.
Best regards
Hans Lagerström, Sweden.
ZCODE pls, I will try to print it on our printers ;)
Here we go. Thanks for your attention.
https://drive.google.com/file/d/0B3ivJdx6hFj_eVR2Y0NKbkRFNE0/view?usp=sharing
I have the same problem!
Using 0.0.9.6 now.
I have printed it straight from your ZCODE, no problem (Shifting) at all:
https://cloud.zortrax.com:444/index.php/s/iMCnsFbFIWybf8o
https://cloud.zortrax.com:444/index.php/s/b9L7iBBQK0euTbh
https://cloud.zortrax.com:444/index.php/s/hH0F3AqVgmSTSjO
https://cloud.zortrax.com:444/index.php/s/xqBDohLbbBLQI9t
https://cloud.zortrax.com:444/index.php/s/EfSJ4OL82ZJfiSc
I would recommend you performing [url=http://support.zortrax.com/axes-maintenance-m200]full XY maintenance[/url]
Hi Marcin,
thank you so much for your support.
I did the axis maintenance again, but there were unfortunately no issues.
I reprinted the part with 180° rotation without any issues.
After that I printed an other part with z ultra. I printed this part before at least 5 times and had very good results with this part positioning.
The last print is a little disaster.
Warping, shifting and incomplete support.
Now I will try the 1.1.0 version, anyway I’m expecting deviation of the z axe.
Today I did a software downgrade to v1.0.1I also will try the v0.9.6 next.
v1.0.1 or v1.1.0?
V1.1.0
V1.1.0 prints slightly cleaner with z-ultra than with v0.0.9.6
For now I will stick with v1.1.0
Hi Polinizei,
Quite interesting.
Thank you for spending time to reveal this and also sharing it.
Best regards
Hans Lagerström
Thanks too,
Have some trouble similar to your print, will try with te V1.1.0.
Which firmware do you used (V1.0.4)?
I use firmware v0.0.8
Why not the last one ? did you test the last one and roll back to v0.0.8?
