Hi all. Due a blockage of head extruder the layer fan holder has broken. It 's also the calibration sensor support. It´s a 3d printed item but I can´t find either new either a STL file to print a new one. Where can I find that piece? Thanks a lot.
Nothing? Must the printer go to trash because I can’t find that piece?
Hello Jose,
Could you send me a photo of the broken piece?
Thank you for the photo please find below:
Fanshroud-M300Dual.STL (597.4 KB)
Best regards
Thank you¡¡ Best regards
@KarolinaZ Could you please add the file to the library?
I needed it as well, thank you @Pawel_Zortrax
By the way, could someone provide a photo or schematic of how the fan should be placed (and screwed in) in this fan shroud? I kind of can’t fit it…
Hello @Tommar,
I will pass your suggestion to the responsible department.
Please have a look at this manual. I hope it helps.
I forgot to edit the post. I handled it in the morning, just pressing it under the small ledge works fine. Thanks.
