From time to time, we experience this issue with our M300 plus.
Everything is updated to newest versions.
If we experience this issue, the same file will make layer shift in different positions. The only way to eliminate it, is to generate a new zcodex file.
Anyone else with this issue - and how was it fixed?
@mikegregersen,
I would not suspect a problem with a .zcodex itself - especially that the problem occurs randomly while printing exactly the same file, which was printed without a problem previously. Also, layer shifting would not occur in different positions. I assume the printer requires the axes maintenance, so please, follow these steps first.
Best regards
