On a mechanical part that had to withstand the impact of a drop of one meter high, we chose to print it in HIPS with a 0.6mm nozzle with a 40% honeycomb filling.
Unfortunately, the filling does not come into contact with the walls, whereas usually the filling covers the walls by about 15%.
As a result, from the first fall, the energy of the shock did not dissipate in the filling and therefore broke the wall.
Is it possible to correct Z-Suite so that it refills the filling when using a nozzle diameter 0.6mm?
Thanks in advance.
Johann
