Dear users,
Firmware 2.4.0 - supporting Zortrax inCloud - has just been released. Full changelog available below:
M Series Plus
- Added support for Zortrax inCloud,
- Added new printer statuses in My Devices panel in Z-SUITE,
- Changed the minimal loading temperature for external materials,
- Simplified material management in the pause menu,
- Improved heating control menu – printers will now start to heat up once the user presses ON,
- Added a warning for cases with camera problems,
- Printers will now wait 5 minutes for the user to remove excess material from the nozzle when resuming the printing. After this time, the printing will be resumed automatically,
- Stability improvements when booting up [M200 Plus]
- Changelog for each update will now be available to view before installation,
- Fixed a bug where printer settings, e.g. for LED colors, would be deleted,
- Fixed a bug where the sprocket wheel could stop for a short time during material loading with the Ignore material jam option enabled,
- Fixed a bug where material unloading would continue for a short time after reaching 100% with the Ignore material jam option enabled,
- Fixed cases where LEDs would change their color during a failsafe response,
- Fixed a bug with the buzzer; it is now possible to turn it off.
M300 Dual
- Changed hotend symbols; hotends are now marked (A) and (B) in the entire menu,
- Improved the autocalibration procedure in terms of precision and reliability,
Inkspire
- Fixed resin level count for prints which are started in Z-SUITE.
As always - you can download the firmware here.
