Dear users,
firmware 2.5.7 has been released. Full changelog available below:
M Series Plus:
- Fixed a bug where temperature would occasionally drop after changing temperature settings in the menu,
- Notifications on the heated extruder now disappear once its temperature is save for the user,
- Improved and optimized connection with inCloud and Z-SUITE,
- Added a warning about an unstable connection with inCloud, after which printers do not attempt to reconnect again,
- It is now possible to reset ethernet settings during factory reset,
- Fixed a bug where Autocalibration procedure would freeze,
- It is now possible to disable screensaver in the Working options menu,
- Screensaver now shows the Sleep mode status and a single tap wakes the printer up,
- Fixed a bug where Android application would freeze at the end of printing after choosing the Stop print option,
- False material jam errors are now less likely to occur with Z-ESD and Z-ESD v2
M300 Dual:
- Improved camera stability,
- Layer shifting is now less likely to occur,
