Dear users,
new firmware versions have just been released. Full changelog available below.
M Series Plus (2.6.9):
- Added support for Nanovia PC ABS V0
- Added support for BASF Ultrafuse ABS
- Printers now switch to Idle Temp mode only when the user clicks Done after printing
- Platform offset is now reset after each calibration
M300 Dual (2.6.9):
- Added the possibility to select the nozzle diameter
- Added support for BASF Ultrafuse BVOH
Endureal (2.6.9):
- Added the possibility to select the capacitive sensor version
- The Annealing option is no longer available
- The axis check option is no longer available
Inkspire 2 (2.6.9):
- Improved settings for UV exposure of first support layers
- Added support for BASF Ultracur3D RG 3280, Ultracur3D RG 35 B, Ultracur3D RG 1100 B, Ultracur3D ST 1400
Inventure (1.6.1):
- Added support BASF Ultrafuse BVOH
- Improved operation of the printer’s fans
- Added the Fan test option in the Maintenance menu
- It is now possible to reuse cartridges without the need to reprogram the RFID tag
As always - you can download the firmware here.
If you have any suggestions - feel free to share your feedback.
