M200. Edges of raft releases often
This problem occured a while ago and its always the same since.
The outer 2-3mm of the raft releases from the hot bed. Not all around but at some points here and there. Doesn’t matter if the print is round or square. This will make a completely straight bottom surface kind of banana shaped.
Any thoughts?
Calibration is pass.
I use zortax ABS filament and default settings
Hi @newbadboy,
please, have a look at the troubleshooting manual. Thanks to these tips - your models should fully adhere to the platform.
