I was printing a model overnight and the filament ran out about 2/3 the way through printing. I think this means the filament went past the stepper motor that pushes the filament, and the end of it must have been there. I’ve tried loading a new spool of filament but the stepper motor just clicks trying to push the filament down, but it won’t go. I’ve also tried pulling back the plastic sleeve and adding some gentle pressure on the filament, but that doesn’t help.
So I tried taking off the print nozzle to see if that would allow the last little bit of the filament from the last spool to be pushed out when doing the load, but it isn’t moving.
How do I fix this? Is it likely a stuck piece of filament that is my problem?
