Never posted here before. I have a M300 with V04 hardware but the Marlin download only has V05? does that mean the V04 hardware M300 isnt supported with marlin?
Can everybody tell me what slicer your using and printer profile ?
thankyou
I tried downloading marlin on my m300 but it downgraded from my original firmware instead of upgrading to marlin, what can I do to actually get marlin working?
I think that might be the case, marlin didnāt work on my m300 either.
Hi!
Iāve connected my RaspberryPi Zero 2W to the debug header as the instruction on github said: RX to TX, TX to RX and GND to GND. I wanted to use OctoPrint, serial connector is ON on my raspberry, but OctoPrint canāt connect to the printed by any chance.
Also after this update bed temp canāt be reached, it stopps at around 70 deg and then printer shows an error of bed heater and reset is needed. Everything works on earlier firmware version tho.
EDIT: After some digging I think that my problem with OctoPrint is not with connection but with baudrate as my RPi canāt handle 250000, so Iāll need to buy a USB-UART converter or to ask developers to change baudrate for example to 230400 if itās possible.
Also the problem with bed heating might be that marlin expects it to heat faster, and if it wonāt reach temp fast enough it ends with an error, because if I heat it to 65 deg and then set temp to 70 deg everything is fine, but not if I set it to 70 at once. Maybe changing bed temp check from 6 to 2 or something like that could fix that issue too.
Any help much appreciated!
