the PSU fan is making a big noice when the M200 is just powered on.
and it each time it seems longer…
Could you tell me what fan type to buy to replace it ?
Thank you.
Best regards
Thank you.
Best regards
You can purchase a spare part from your local reseller or contact us via support form.
I can’t find it in France, only motherboard FAN or extruder.
But not the PSU part… Maybe you don’t sell PSU FAN only but all new PSU ?
I am sorry, I thought you were referring to to the 70x70 fan underneath the bottom plate. Yes, the PSU fan cannot be purchased separately - you need to ask your reseller for the PSU (service part).
Ok so I’ll open the PSU and find a corresponding FAN on Amazon or Ebay… Thanks.
For those like me who want to replace the PSU fan and not the whole PSU…
I opened the PSU.
The fan inside is : ARX DC BRUSHLESS 6015 FD1260-S1112C DC12V 0.19A 60X60X15
You can find it on Aliexpress…
I’ve had really good luck with swapping out failed OEM fans with Noctua-branded fans.
I did the Z-vent upgrade :
(You don’t need it if you only do ABS and Ultrat.)
I finally received the PSU Fan from aliexpress and replaced the noisy one…
It works fine as expected.
