Howdy Folks,
Since purchasing the unit I’ve enclosed the unit, moved to HIPS, swapped the bed 4 times, swapped in fresh nozels, run through the calibration / fresh abs-juice / etc many many times.
The problem is that the rear left quadrant raft ALWAYS lifts. If I rerun the calibration multiple times in a row it always says the unit is not calibrated. Since day 1 the calibration screws in the back have felt ‘loose’
Has anyone else run into this issue and if so do you have a solution or guide you can point me to?
Thanks folks,
Chris
Hello Chris,
Let me, please, sum everything up - you are unable to calibrate the printer, right? What values are shown on the screen?
Also, the calibration screw in the back seems loose - is it actually possible to tighten it as other ones? I am wondering if the platform regulating distance should not be replaced with a new one. Can you record a video showing what happens when you try to tighten it? Any picture of the warped model would be helpful as well.
Howdy Karolina!
I believe this is the root issue.
-0.2 Rear Left
-0.1 Rear Right
+0.2 Center
-0.1 Front Left
-0.1 Front Right
If I take the printbed off and look at the screwhead on the top of the spring – the rear left one just spins free. The rear right and front screwheads above the spring don’t budge. In addition – tightening or lossening the thumb knurl has very little resistance on the rear left unit & it has been this way since day 1.
How to tighten the ‘platform regulating distance’? I’m not sure how to do this.
3 pictures are attached
UsableArea (print in light grey) shows the platform area that always provides great prints.
The other 2 show a print that extends 10mm out from the center towards the 4 corners. The 3 corner prints fail consistently if printed in the center of the printer.
Thanks for helping!
Chris
