Could you add a XY diagonal (go and back 10 times). It will be usefull when apply grease.
Thank you.
Thank you.
Hi!
You have something like axes check to see if everything is fine with the geometry.
When it comes to applying grease - it’s easier and quicker to move the extruder manually.
Kind regards,
Marcin
There is on M200+ and M300+ but not found for M200. Where is it please ?
Thank you for your help.
Fabien
My bad, I thought you have an M200 Plus.
There is no such a feature for the M200.
Could zortrax generate a simple zcode do do that ?
