No, the printer is right, your current firmware is the recommend one by zortrax. If you wish to update you will have to do it manually. Download the image from zortrax, upload it to your usb, then go to the menu to check for updates. It will instantly ask you to update.
Maybe it should, but it doesn’t.
I downloaded: https://support.zortrax.com/wp-content/uploads/2024/12/Firmware-2.7.1-M200_Plus.zip
which has an MD5 of:
ed55b7e3d41890ee6ceacbe8662b980b Firmware-2.7.1-M200_Plus.zip
I unzipped it to update.zar2 which has an MD5 of
23daf06778d4f34d2acd1be5ffb2b2bd update.zar2
I put update.zar2 on the root of an empty 4G USB thumb drive formatted for FAT32 and inserted it in the printer, and power-cycled the printer
The ‘About’ menu ‘check for updates’ still thinks I’m up to date.
Tried it on a Windows10 machine, tried formatting the drive as FAT instead of FAT32, same MD5, same LOST.DIR, same “You are up to date with a firmware release date that doesn’t make any sense”.
On a Linux machine (Raspberry Pi 5, Raspian/Debian 12.9):
[NOTE! In my case the USB thumb drive was /dev/sda, don’t do this on a machine for which this isn’t true!]
shred -f -n0 -v -z /dev/sda
mkfs.vfat -F 32 /dev/sda1
fdisk /dev/sda
<follow fdisk instructions from How to create FAT32 USB drive on Linux – Redips spideR Net >
mount /dev/sda1 /mnt/scratch/
cp update.zar2 /mnt/scratch
umount /mnt/scratch/
Now I have only one partition, FAT32 with just that one file on it, and that worked for installing the 2.7.1 firmware. There’s probably a way to zero the drive and generate a single FAT32 partition on macOS or Windows, but I’ll et someone else figure that out.
Thanks!!! I tried to update since 2.6.17 and stuck in 2.6.15 until saw your method
I used win10 device, formatting usb thumb to exfat 4kb and put only the zar2 into the drive, plug and reboot the machine and finally work!
i was so willing to upgrade today cuz just saw the bambu h2d got lots of problems, so wanna get best performance from this machine, so i factory reset my m300d, sad, need to redo all the calibrations
