I have a Zortrax M200Plus. The printer is connected to internet by ethernet. I can’t update it automatically. Currently the 2.5.11 is installed. When I check updates, the printer said “your printer is update” but the 2.6.0 version is available on your website
providing that Ethernet connection is stable and you can send the files through Z-SUITE/inCloud - I assume there might have been some problem with the server. Please update the printer via USB to the newest version (2.6.0) - you only need to download the update and copy update.zar2 file onto the USB. The printer should detect the update automatically once you insert the drive. If not - restart it. When the new update has been released - check if the device will detect it. If not - please check the Wi-Fi connection.
