I have an old model M300. The firmware is updated (version 1.3.1)
I have just updated Z-Suite to version 3.6.0.0.
And now Z suite is producing printing code files with extension .zcodex2. And my machine can’t read these files.
Version 3.6.0.0 is only dedicated to M300 Plus machines.
How can I get the previous version of Z-suite that is still compatible with M300 machines? (i.e. provinding .zcode file extension)
Thank you.
Hi @VincentRaquin,
Z-Suite 3.6.0.0 does not support the M300 printer. If you want to keep using that device, you’ll need to download the 2.32.0 version from the support center. Keep in mind, that you’ll need to install that old version in an another location to not override the currently existing Z-Suite instance.
We are currently working on a better solution to support our legacy devices. Thank you for your patience.
Ok, thank you for your help.
