M300+ Door Hinges
Hello! My M300+ has been working very well, but… the front door falls off every day. Apparently, the hinges were glued to the frame with some sort of black glue (maybe heat-resistant). Can someone advise me on what type of glue to buy to glue the hinges back?
A very annoying problem, by the way…
Thank you!!
I remember mine had double side tape, the thin one but didn’t hold so much
Anyway you can warm them and bend to make more pression to the frame.
You need a heat gun do do it
Thank you! I think I’ll do both… I will heat bend them and also apply heat resistant glue. Overkill maybe :slight_smile:
