I have tried on multiple sd cards and flash drives that 100% work.
It DOES see older Zcodex files and NOT new zcode.
Z-Suite will NOT write .zcodex it will only read older zcodex.
How should I print on an M300 plus?
What firmware version do you have?
Which Z-SUITE do you use?
Please send me the zcodex files that do not work. I’ll check them.
Kind regards,
Marcin
Hi @Montrose,
also, please make sure you set the right printer model in Z-SUITE - otherwise, the software will generate .zcode files which cannot be read by M300 Plus. You can also set your default printer here: File -> Preferences.
Thank you!
I did not realize that there was more than one model of M300 single extruder, that solved the issue.
Can I use third-party slicers with M300 plus? I have found converters to zcode but not zcodex?
Hi @Montrose,
You are welcome, we are glad you found a solution.
We do not recommend using third-party slicers - Z-SUITE is our dedicated slicing software, and please note that the printer will not recognize any other files than .zcode ones (.zcodex/.zcodex2 files are dedicated for M200/300 Plus, M300 Dual, Inkspire).
