What does turning off the Material end stop do?
Dose it allow you to use the remaining material in the cartridge even if the cartridge shows 0. The reason I’m asking is because one of my cartridges Ultrat Plus jammed with 300grams left in it, I destroyed the little tag under the Zortrax sign some kind of magnetic tag (looking for the screws) then had another cartridge with only 9 grams also Ultrat Plus, so I swopped the material from one to the other will this work?
Hi @Airboy_131,
Turning the material endstop off allows you to load the filament from the spool. Thus, it would be better to take the remaining material out of the cartridge and load it from the spool (after disabling the endstop).
