I’m the tech director in a high school, exploring our new M200 Plus [which our reseller helped with - they did an excellent job - Paliproto out of Atlanta area].
Had a couple of basic questions about setup and networking that I’m hoping someone can help out with:
Any limitations or issues with attaching the printer to an ethernet network compared to wireless? I haven’t seen any [yet], but I’m still new to this…
Is the camera only accessible via the Zsuite software? Can it be accessed over the network [say, via web browser]?
I see from the videos and such that you can print over the network, but I’m having trouble getting that to work. Any suggestions or resources you can point me to?
Finally…Macs. I’m running Mohave 10.14.6 - downloaded the Zsuite and the Mono packages and installed them - but the Zsuite won’t start up. The windows version is working fine - but we’re a dual-platform school.
Sorry if this is a bit much - I’m squeezing this little project in between a few thousand other tech emergencies.
Then again, I’m not bored!
You should be able to connect the printer to both Wi-Fi and Ethernet and use it without any issues and limitations. Here is an instruction on how to do it.
Yes, camera is accessible only via Z-SUITE.
After adding your printer to my devices panel you should be able to export sliced models directly to the printer. Remember that USB stick should be connected to the printer if you want to export the file and start the printing process. Can you precise which step is troublesome?
First launch on MacOS can take longer than usual. Did any error appear when you were trying to start Z-SUITE?
default 09:08:37.260155 -0400 loginwindow -[PersistentAppsSupport applicationReady:] | App: Z-Suite, ready, updating active tracking timer
default 09:08:37.260922 -0400 loginwindow -[ApplicationManager checkInAppContext:refCon:eventData:] | checked in app : Z-Suite
default 09:08:37.346696 -0400 amfid /Applications/Z-Suite.app/Contents/MonoBundle/libZortraxNativeWrapper.dylib signature not valid: -67050
default 09:08:37.341866 -0400 kernel AMFI: ‘/Applications/Z-Suite.app/Contents/MonoBundle/libZortraxNativeWrapper.dylib’ is adhoc signed.
default 09:08:40.650696 -0400 launchservicesd CHECKIN:0x0-0x137137 9566 com.zortrax.Z-Suite
default 09:08:40.652078 -0400 loginwindow -[ApplicationManager checkInAppContext:refCon:eventData:] | checked in app : Z-Suite
default 09:08:40.674767 -0400 Z-Suite Current system appearance, (HLTB: 1), (SLS: 0)
default 09:08:40.679276 -0400 Z-Suite Post-registration system appearance: (HLTB: 1)
default 09:08:40.689766 -0400 distnoted register name: com.apple.xctest.FakeForceTouchDevice object: com.zortrax.Z-Suite token: f4267 pid: 9566
default 09:08:40.837051 -0400 Z-Suite NSApp cache appearance:
-NSRequiresAquaSystemAppearance: 1
-appearance: (null)
-effectiveAppearance: <NSCompositeAppearance: 0x600003748d70
“<NSAquaAppearance: 0x60000013d7c0>”,
“<NSSystemAppearance: 0x60000013d780>”
default 09:08:41.683935 -0400 Z-Suite
Unhandled Exception:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.UnauthorizedAccessException: Access to the path “/Users/tomrule/.config/Zortrax/” is denied.
at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x0005f] in /Users/builder/jenkins/workspace/build-package-osx-mono/2017-12/external/bockbuild/builds/mono-x64/mcs/class/corlib/System.IO/Directory.cs:121
at System.IO.Directory.CreateDirectory (System.String path) [0x0008f] in /Users/builder/jenkins/workspace/build-package-osx-mono/2017-12/external/bockbuild/builds/mono-x64/mcs/class/corlib/System.IO/Directory.cs:85
at A.^B^]. () [0x0000c] in :0
at A.^]^]…ctor (System.String ) [0x0005a] in :0
at A.^W^D^]…ctor (System.IntPtr ) [0x000ef] in <84f0f69392ab4a6ab73d305451c54590>:0
at (wrapper managed-to-native) System.Reflection.MonoCMethod.InternalInvoke(System.Re<…>
default 09:08:41.711397 -0400 loginwindow -[PersistentAppsSupport applicationQuit:] | for app:Z-Suite, _appTrackingState = 2
default 09:08:41.711425 -0400 loginwindow -[PersistentAppsSupport applicationQuit:] | App: Z-Suite, quit, updating active tracking timer
default 09:08:47.860301 -0400 loginwindow -[PersistentAppsSupport applicationReady:] | App: Z-Suite, ready, updating active tracking timer
default 09:08:47.860468 -0400 loginwindow -[ApplicationManager checkInAppContext:refCon:eventData:] | checked in app : Z-Suite
default 09:08:48.616536 -0400 launchservicesd CHECKIN:0x0-0x138138 9567 com.zortrax.Z-Suite
default 09:08:48.617805 -0400 loginwindow -[ApplicationManager checkInAppContext:refCon:eventData:] | checked in app : Z-Suite
default 09:08:48.645758 -0400 Z-Suite Current system appearance, (HLTB: 1), (SLS: 0)
default 09:08:48.649795 -0400 Z-Suite Post-registration system appearance: (HLTB: 1)
default 09:08:48.659354 -0400 distnoted register name: com.apple.xctest.FakeForceTouchDevice object: com.zortrax.Z-Suite token: f4267 pid: 9567
default 09:08:48.677395 -0400 Z-Suite NSApp cache appearance:
-appearance: (null)
-effectiveAppearance: <NSCompositeAppearance: 0x6000026fc9b0
“<NSAquaAppearance: 0x60000108f380>”,
“<NSSystemAppearance: 0x60000108ed40>”
default 09:08:49.013836 -0400 Z-Suite
default 09:08:49.042681 -0400 loginwindow -[PersistentAppsSupport applicationQuit:] | for app:Z-Suite, _appTrackingState = 2
default 09:08:49.042713 -0400 loginwindow -[PersistentAppsSupport applicationQuit:] | App: Z-Suite, quit, updating active tracking timer
This may be the culprit:
That directory is owned by root:staff - and I am unable to cd nor ls it.
Please, try to change this catalog’s name or delete it and try to launch Z-SUITE. Does any error appear then? We will know which file causes the issue.
